Old 03-10-2003, 01:47 PM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
either the signal wire to the solenoid is hot all the time, or you just keep welding the contacts. If the signal wire is NOT hot, then give a light whack to the top of the solenoid, that usually unsticks them. I used to always have a 1/2" wrench in pocket to whack the top of the solenoid if necessary.
