Old 03-10-2003, 03:05 PM
tommachine73 tommachine73 is offline
Doug
I had a similar problem. Here is what I did! First get yourself some 2.00 diameter d.o.m. tubing .125 wall .Go down to your local midas muffler shop they will bend it for you at a reasonable price. You need to make some .500 x 3.00 steel plates one gets welded to the rollbar the other gets bolted to the floor right over the frame thats important as it must withstand the weight of the car.You also must have at least 2 other cross bars triangulated so that they form a pryamid .Note these 2 other bars must bolt to the rear bulkhead and,then down to the main frame.I spent about 400.00 in materials plus the bending this also included powder coating the frame. I suggest going to a machine shop in your area to fabricate the plates.Any thing less I would not suggest ,after all its your life on the line.
Regards
tommachine73
