Old 03-10-2003, 03:45 PM
Sizzler Sizzler is offline
It's going to be a dyno engine only, running in a limited (low) rpm range.
I wouldn't get all exotic.
4.25 bore x 4.125 stroke, loose bearings, sideoiler block not important unless that's the only one to go 4.25 bore.
More important would be the intake and head porting. Should promote low-rpm flow and some work as needed on the exhaust port. Proper cam selection, electric water pump.
Tunnel ports and SOHC heads work outside the range, except I don't know if maybe they might not be needed given the displacement.
