Old 03-12-2003, 01:57 AM
GUMBALL UK GUMBALL UK is offline
Default MSD ignition timing
Hi guys,
It has come time to buy a new timing light as my present one will not read the signal from the MSD6AL correctly (it's a dial back timing light).
Now, it is pretty well known that dial back timing lights do not work well with this set up, so what are you using or what do you recommend???
I don't want to spend a fortune on an MSD timing light unless I have to, as they are a lot of dosh in the UK, but if that is the only way - then so be it.
GUMBALL UK
