Stay away from it, it eats rubber hoses gallore. If you must use anti freeze, use the traditional green stuff. Better yet, don't use any at all, just drain the system at the end of the season.
You may want to add water wetter if you use straight water. It has conditioners in it and will normally reduce temps. by 10-20 degrees.
Jeff
“If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough horsepower.”
Mark Donahue
