Old 03-17-2003, 03:58 PM
tim tim is offline
Cobra Make, Engine: Everett-Morrison, Boss 351 w/ TKO 5 speed, 94 vette suspension
Place the caliper with pads as you have described back onto the caliper mounting bracket WITHOUT the spring and L shaped clip. Place the spring on top of the clip and wedge the end between the caliper and the mounting braket and tap it in with a small hammer. Make sure you have the clip turned the correct way so that the locking bolt will go through the slot in it and screw it to the mounting braket.
Tim
