Will the inhibitors added allow straight water to be used in a cooling sytem with a lot of aluminum, radiator, surge tank, heads, waterpump etc with out causing corrosion?
I've used the conventional glycol based green coolant in the past but wonered if the above was acceptable.
Rick
