Old 03-19-2003, 04:27 AM
Bill Wells Bill Wells is offline
Cobra Make, Engine: Superformance 156, ex Paxton 351, now a 392 Ford Racing Stroker
tunes....i just installed a Custom Autosound "SECRET AUDIO" radio in my spf. ALL components , including antenna and two large speaker boxes with 3 spkrs in each are mounted under the dash, out of sight. Only thing visible, and it can be removed/ hidden or attached with velcro, is a 1-1/2x4" face plate. however it does not need to be seen to work as the entire system is controlled by a wireless remote . the face plate also swivels up if desired and then only 1/2x4" is barely visible mounted on the frnt edge under the dash just barely peaking thru. the rod folks use this radio often. while not heard going thru the gears due to the sound of the side pipes and the shrill squeal of my blower, when cruising in 4th or 5th gears the radio can be heard. i added a separate toggle switch to depower the system when car is parked so that there is NO battery drain from clock etc, but draw is so low i doubt that it matters. at least now, my long trips on the freeway will have the option of hearing something besides the pipes and blower sounds. a separate cd player from custom autosound can also be located out of sight . this ain't 'live' symphony quality music with hidden speakers but it works well enough for my purposes. after all, it is a secret, right ? bill
