Old 03-19-2003, 11:06 PM
chuckbrandt's Avatar
chuckbrandt chuckbrandt is offline
Club Cobra Member
Cobra Make, Engine: ERA # 665, 390 (to start with) Toploader
Default Yes I'll be sure to investigate that.
Thanks Dan for bringing this up. I plan to use CJ sized valves in a C4AE-G casting head. The 352 will most likely be 030 over which is getting closer to the standard 390 bore of 4.05. So I'm hoping by notching the bore slightly like a 427 it wil be fine. The cam is dual pattern, intake lift is .533, exhaust is .563.
But all that said, I think I'll have the block work done first and experiment with the new valves before having the head work done.
Chuck
