Old 03-22-2003, 03:36 PM
niles niles is offline
Cobra Make, Engine: Hunter #28; 396 Cleveland stroker; more than 495 HP; TKO 5 speed
Chuck;
start with some diagostics; that isolate areas.
1. Pull plugs and turn over; if slow; starter, solinode, cable grounds(grounds, GROUNDS!!!) they can't be over enphasised; you need two or three. I have engine starter bolt to frame, bell houseing to grn bus. battery neg to frame in rear of car.
If fast; timing? Too small cables- can't take starter amp load
Do you know if starter is good?
gn.
