Old 03-23-2003, 09:48 AM
Anthony Anthony is offline
Cobra Make, Engine: CSX4000, 427
Assuming the timimg chain is aligned correctly and timing marks on the dampner are correct, you need to tale the valve cover off of #1 cylinder. Watch for the intake valve to close, and continue turning the crank clockwise until #1 piston is top dead center. This should be at the 0 mark on the dampner timing marks.
Take the distributor cap off, and see which of the 8 contact points is close the rotor. Make that one #1 cylinder, twisting the distributor so that contact point is aligned with the rotor, and then just attach the rest of the plug wires in the firing order. This should be close enough to start the engine. Once you get the engine running, you can set the idle speed and correct timing with a timing ligt and rpm gauge.
"After jumping into an early lead, Miles pitted for no reason. He let the entire field go by before re-entering the race. The crowd was jumping up and down as he stunned the Chevrolet drivers by easily passing the entire field to finish second behind MacDonald's other team Cobra. The Corvette people were completely demoralized."
