Old 03-24-2003, 08:10 AM
agro1 agro1 is offline
Cobra Make, Engine: SPF - 427 Stroker
Originally posted by Blake Olson
I was just going to have the local welding shop open them up, remove whatever is in there, and re-weld them...
I started the motor with just the headers yesterday..man...drove down the driveway and back...lot's of "poppin", backfiring, etc...
is that normal??
blake
Blake - You do need a certain amount of backpressure otherwise you will have that backfiring and poping...And, you also get too much backpressure when you try and hollow out the pipes and make the exhaust run that far - it can actually cause you to drop hp...The "shorty" method Slow Dawg mentioned is usually the best solution - for the track...Doing it on the street might attract a little TOO much attention.
NEVER LIFT
