Old 03-24-2003, 02:40 PM
Chuck Nickloy Chuck Nickloy is offline
Paul,
The enginr we are using is a 2000 mo/yr. Upon Paul Faessler's recomendation, we had him replace the rods and pistons and ballance the rotating assembly. The cams and valve trane are pretty much stock. Vortex supercharger and Fast computer with electronic distributer. This engine with good fuel should make about 700 HP. We are toying with twin fuel tanks and should be able to run pump gas and with the flip of the switch be on the good stuff. Pump gas should be around 500 Hp. Engine will turn a strong 7500 RPM if you like
