Old 03-24-2003, 04:22 PM
petek's Avatar
petek petek is offline
Cobra Make, Engine: CRL, 351W, Tremec TKO
Bad coil, bad points... one or the other.
Positive side of the coil should be hot all of the time. Negative side should show hot and then ground as the points open and close.
Of course the above is all wrong if you are using and electronic distributor and an ignition module.
Pete K.
Who is John Galt?
