  #30 (permalink)
Old 03-26-2003, 12:50 PM
427SSSS's Avatar
427SSSS 427SSSS is offline
Cobra Make, Engine: Hi-tech body/frame, 427engined FF5/302engined FF5 Bennett 289 & 427 rolling chassis
Pete C'
{{I got the pin-alignment tool from Trigo to set the pins right prior to mounting wheel}}
Yes the pin does fit any of the holes on it's own.
I just don't understand why it needs to be such a tight fit, the other three wheels did fit, but barely.
Seems to me the pins could be made out of a harder material, when tapping them into alignment so they will fit thru the "pin-alignment tool" from Trigo they can be damaged really easy, after the first couple of taps, I started using a block of wood btwn the hammer and the pin so as to not dent/damage the pins.
Albert Einstein
Two things are infinite: the universe and human stupidity; and I'm not sure about the universe.
