Old 03-26-2003, 12:59 PM
xlr8or's Avatar
xlr8or xlr8or is offline
It may be an issue with needing to bleed the brakes as well.
If you have air in the front lines or calipers you will not get the line pressure required to use the brakes effectively.
I would go with a good bleeding first before messing with the brake bias. Otherwise you'll just have to go through adjusting it again later when you change brake pads and bleed them properly.
Scott
