Old 03-29-2003, 07:45 AM
Bud Man's Avatar
Bud Man Bud Man is offline
Cobra Make, Engine: Former Owner/Builder of KMP142 427 Sideoiler, Tunnel Wedge, Aluminum heads, etc.
Its easy enough to mike your pins and holes to see if there are restrictions, but don't forget to use a light coating of anti seize on the pins and hub threads prior to mounting, and occasionally remove your wheels, clean the pins and wheel holes, and recoat with anti seize. There is always the possibility of corrosion and galling, due to the contact of aluminum (wheel) and steel (pins).
Bud
