Old 03-30-2003, 11:43 AM
Rick Parker's Avatar
Michael:
First off let me say I have not worked with a set of Trigos and do not know how deep the pin holes are machined into the mounting pads on the back of the wheels. Would it be possible to remove material from the pad to effectively reduce the track width when they are mounted and if necessary shorten the pins too?? You had mentioned that the tires were near the wheel lip opening when you finally got them mounted?? Am I oversimplifying your problem??? This is how the various offsets are created in the first place once the wheel width is finalized.
Rick
Rick
