Old 03-31-2003, 10:03 AM
dscott's Avatar
dscott dscott is offline
Cobra Make, Engine: Owner, Classic Roadsters II
Brose, Don't get down on what you have! When I talk about changes most of the time it's to update some of the Mustang II donor parts that are hard to find. Ed and I have worked with Classic to change things like the radiator, fan, heater, motor mounts, etc. Changes I want to make are in the way the door hinge mounts, trunk hinge, wiring system, etc. I just went through the muffler change with the sidepipe mfg. I want to upgrade some of the components like the door opening system, seat belt mounts, etc. These are things that can be changed on your car with no problem. The basic design will remain the same. Ed and I already do most of the changes now, we just want to make them available to everyone to aid in the building process.
This car hasn't had any updates since it was introduced back in the early 90's so it's time. One of the other things to change is the manual. It needs to be updated as well.
So your car is fine. Don't worry about any major changes and, the small changes you can do now.
Don
