Old 04-02-2003, 09:13 AM
Mr.Fixit's Avatar
Mr.Fixit Mr.Fixit is offline
Are you referrong to the rubber bootie with a metal ring that seals the shifter hole from leaking out fluid, or worse yet, letting debris into the tranny? It goes over the shifter handle and bolts to the case.
