Thread: To PCV Or Not ?
Old 04-02-2003, 02:38 PM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Default I had to install them on my 514
Most crankcases have a very low positive pressure, and it gets much worse if you romp on it, in my case enough to blow a slight oil mist out the dipstick, (naturally ) right onto the headers!
I installed a billet PCV & breather and a ss hose/AN system, ......breather on the driver's side, (hidden in a billet breather look unit) PCV in the passenger's side, fed into the intake thru a port. You can also feed it into the large unused tube sticking out of most carbs, but since my carb is temporary, it made sense to put it directly into the intake. No leaks now except for a tiny weepage around the rubber grommets, no big deal at all. For the dipstick I bought a nice billet dipstick and ss tube system, perfect now. The stock unit from Ford was not street worthy.
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
