Old 04-03-2003, 07:50 PM
Dwight's Avatar
Dwight Dwight is offline
CHECK INTO A HIGH TORQUE MINI STARTER. COACH MIKE AND I HAD THE SAME PROBLEM. INSTALLED THE MINI STARTERS AND NO HOT START PROBLEMS. BUT FIRST CHECK THE GROUND CONNECTION AND CABLE SIZE. GROUND THE MOTOR TO THE FRAME WITH A GOOD CABLE. HEAT SHIELD DID NOT WORK FOR US. LOCAL HOME TOWN PART STORE HAD THE STARTERS FOR A $130 EXCHANGE.
