  #25 (permalink)
Old 04-06-2003, 11:37 AM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Thumbs up I just changed my oil and filter at 400 miles
K & N gold (it's a white can for some reason now, K&N # 3001) and Valvoline 20/50 racing oil, a standard non-synthetic for break in. My oil pressure jumped by 10 PSI hot, and stays higher longer !
I am not sure how much contamination my oil took, so that might be the culprit in the lower oil PSI, or it could have been improper wt oil as delivered. .. I had something small stuck in my secondary needle/seat, it was flooding out my carb at idle !
Initially, PSI cold= 75 PSI hot (200 to 210F) = 45 to 50 psi
NOW, after the change:
PSI cold = 80 PSI "hot" = 50-60 !
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
