Old 04-07-2003, 07:26 PM
Scott S's Avatar
Scott S Scott S is offline
Charter Club Cobra Member
Cobra Make, Engine: My Shell Valley Coupe is here! Now the building begins....
If your waterpump exits on the drivers side the pulleys will not line up if you have an older 3 bolt dampner. Also I think that the timing marks will not be in the correct postion also. Most all of the 3 bolt pulleys and dampners used a passenger side exit pump which has a slighlty shorter shaft.
Scott S
Working as hard as I can every day to double my carbon footprint.
