Old 04-10-2003, 06:53 PM
excelguru's Avatar
excelguru excelguru is offline
(An All-Around Nice Guy)
Cobra Make, Engine: Unique Motorcars (sold)
Smile
I have a 427 block with a Canton oil pan... one of those wide T-shaped ones. On the driver's side, mine had a plug mounted on the top of the tee section, near the rear of the pan. I removed the plug and installed my temp sensor there, pointing down into the oil.
My engine is fitted with a remote-mounted oil filter. So there's an adapter on the engine block where the filter would normally mount. In addition to the inlet and outlet connections, the adapter also has a small threaded port to connect the pressure sensing line.
Keith
Keith
Former Unique owner.
