Old 04-11-2003, 09:40 AM
Whaler Whaler is offline
Guys good tips thanks!
As for air. The only thing I did do was fill the entire system until i saw it at that specified level in the expansion tank. I did this 2 days prior and it got a chance to burb out. I drilled a 1/8 hole in the top of my thermostat too. I had assumed that it would be ok
Good advice to leave that cap off. I guess I could have monitored it better. Will the cycle of heat and cool cause me to lose a alot out the overflow often or does this only happen until the point that there is no "excess coolant" and it has found a balance
Last thing, my pal had the top of his running shoe's tongue melt to my drivers side side pipe on more than one spot. Most of it is coming off but there are some thicker goops. Would a heat gun work in getting it soft again?
Tim
