Old 04-11-2003, 01:54 PM
Chaplin's Avatar
Chaplin Chaplin is offline
Cobra Make, Engine: Original ERA 427sc, Powered by Gessford
Roscoe-
I have a question for you. Based on your recommendation (read that if it sucks I'm blaming you- just kidding ) I bought a Pro 5.0 for my TKO II. Since I don't have the car yet (coming soooon) and nothing better to do, I installed the new shifter on the trans the other day.
Here's the question:
The stock shifter had a plastic cup on the end of the shifter mechanism where it engaged the gear selector inside the transmission.
I took off the plastic cup and installed it on the bottom of the 5.0 shifter and then bolted it on the transmission. However, since my 5.0 shifter came with no instructions, I was wondering if I was supposed to use that plastic cup.
Did you reuse it or install the 5.0 shifter without it?
Thanks,
Mike
Replica is not a dirty word.
