Old 04-11-2003, 05:57 PM
Chad Johnson Chad Johnson is offline
Cobra Make, Engine: Superformance '533'
Chaplin: Absolutely!
FrankyM: Definately go with the Ultra Shift. It is the correct transmission fluid with the correct additives.
1. Drain plug is lower plug on the right side of the transmission. Use a cresent wrench or equivalent, remove and drain old fluid.
2. Replace drain plug
3. Fill plug is just above drain plug. Remove and with funnel and hose inserted into drain hole fill with about 2 3/4ths quarts of Ultra Shift.
4. Replace fill plug-----------------you're done.
Good luck
All I need is a full tank of gas and a clean windshield
