Old 04-13-2003, 09:26 AM
Whaler Whaler is offline
Scott
I opted for a floor mounted pedal assy. Only becuase I wanted it more like the originals.
As you can see in the pic it pretty simple.
The brake uses a dodge application master cyl. new from Raybestos. The clutch uses the McCleod M/C with their internal T/O bearing. The M/C's are mounted tto the backside of that frame rail with the pushrods coming tru to the pedals. Each are fed with remote reservoirs up on the firewall. (3)
Keeps the footbox looking very clean on the other side. As all pedal stuff is done low and below the header under a nice heatshield.
lastly the pedal cluster has a nice aluminum cover plate to go over it and transition nicely from the floor pan to frame rail. Held down with 2 bolts at the front corners and 2 on the back at the rail.
Tim
