Old 04-14-2003, 09:04 AM
sfry's Avatar
sfry sfry is offline
Cobra Make, Engine: EX- Owner/Builder of a Hi-Tech & CSX4264-Southern Automotive 427 Side Oiler,Now I am sitting on the porch!!!
Send a message via AIM to sfry Send a message via Yahoo to sfry
Turk,
I used early FE motormounts that I pick up at NAPA. Like for a 58' Galaxy. Both sides are the same. I also had to use a 1/4" spacer under the left (drivers) side mount. It took all of 30 minutes to install the motor and tranny. It fit perfect. As far as the pipes: Shelby supplies the engine tubes spot welded to the flange. Those spot weld will need to be cut. Fit the side pipe in the middle of the opening in the body. With the spot welds now cut you can begin to fit each engine tube as it pertains to the side pipe location. As you begin to fit each tube, spot weld them so they dont move around. This process took me one full day to complete but it came out perfect.
Shannon
