Old 04-14-2003, 01:16 PM
petek's Avatar
petek petek is offline
Cobra Make, Engine: CRL, 351W, Tremec TKO
The roll bar bezels weren't too tough to install other than getting my fingers and such up under the body to tighten the nyloc nuts. If I remember correctly I did end up cutting a number of the screws shorter.
What I did was install the roll bar with the bezels and gromets sitting quite high on the roll bar. Once the roll bar was in place and anchored down I lowered the gromets and bezels and used a tiny drill bit in my Dremel motor tool to mark the center of the screw openings.
Then I disassembled everything and drilled out the holes for the screws.
Then re-assembled everything and tightened the bezels down over the gromets ... not too difficult at all.
Pete K.
Who is John Galt?
