Old 04-14-2003, 06:18 PM
RallySnake's Avatar
RallySnake RallySnake is offline
KobraKarl,
Wow! I never would have guessed that someone could put the arms together that way. The lower arms are made with a slight bit of toe in. You will notice a tab with a mounting hole that is possibly used for a rear sway bar on your car. When you flip the arms over, you will also have to put the left one on the right side and vice versa so that the sway bar mounts are towards the front of the car.
I fabricated a bracket that the front lower arm bolts to and the other side bolts to the frame. In the rear, I just have a cross beam between the two bolts. I also have the plate attaching the lower bracket together like in the picture below. (Not my car).
Paul
