Old 04-14-2003, 08:06 PM
GEORGE ANDERSON GEORGE ANDERSON is offline
Turk....the mounts for your 4000 are the same on both sides....when you get the second set of pipes you might start your fitting on the front pipe first...cut the front welds and work on the pipe until it's right where you need it.....it woud be nice if you had another head on the bench that you can do the welding work with. Get that first pipe correct on the motor and then do the welding on the extra head and the other three pipes.....
George
Pro-Copper Gaskets on the way...with updated port openings per your request.....Tell Kris Hi!
george
