Old 04-15-2003, 07:53 AM
coyled coyled is offline
Snake farmer, if you have a csx cobra and a fuel cell from fuel safe, I would bet that it is exactly the same as my hi-tech fuel safe cell. I had a similar problem but my cobra is fuel injected. Originally the pick up was on top but went to the back of the cell or rear of the cobra. The rear of the cell is higher then the front of the cell as it mounts in a cobra. It made sense for fuel safe to put the pick up there because fuel goes back there on acceleration, except for in my cobra, the rear of the cell is higher.. I sent it back to fuel safe twice and hear is what they did. They moved the pick up location(still on top) but to the front of the cell. They also gated the area so it would retain fuel. Lastly, they installed an in take fuel pump to make sure that the pick up area would not run dry and thus loose prime. The set up is perfect now. But, I chased this one around for months, died around corneres, would loose prime, only worked well on a full tak of fuel. Finally, solved the problem. You may have to gate the pick up area in the tank, make sure its in front and have an in tank pump to make sure, at least on start up, that your external pump is primed. good luck, scott.
