Old 04-15-2003, 01:41 PM
agro1 agro1 is offline
Cobra Make, Engine: SPF - 427 Stroker
Agreed...The countersink is a a good idea. What would you say about using a larger diameter drill bit, making a bit wider hole and using the nylocks with a washer and rubber grommet on the underside - thus the bezel would almost be "floating" in the drilled holes ?
Also, is there anything that needs to be done to the freshly drilled holes to protect them from cracking or allowing any moisture into the paint ??
NEVER LIFT
