Please don't flame me for asking this. What piston were you checking.. Are you sure it is #1? Here's why I ask..
Here's the thing.. If you are running an aftermarket distributor with no specific reference to #1 cylinder you have likely changed #1 to something else.. seriously.. As long as the same firing sequence (firing order) is observed you can make any cylinder you want "#1".. The symptoms you describe are completely consistant with your observations.
Find TDC again on the #1 cylinder.. Pull the distributor cap.. what wire is the rotor pointing at? There is your problem. Dial in a few degrees.. 8, 10, whatever.. Pull the dist. out and realign the #1 terminal of the cap.. Problem solved..
michael
A man that is young in years, may be old in hours, if he have lost no time. But that happeneth rarely. Generally, youth is like the first cogitations, not so wise as the second. For there is a youth in thoughts, as well as in ages... Sir Francis Bacon (1561-1626)
