Thread: To PCV Or Not ?
  #41 (permalink)
Old 04-17-2003, 06:11 AM
tommyboy tommyboy is offline
Cobra Make, Engine: SPF/white/blue/smallblock427/webers
Has anyone tied to run a pcv with power brakes on a 48IDA weber carb induction system. The eight vacuum port tubes plumbed in underneath the manifold are such small ID(1/16" or so) that I worry they could get plugged. I was thinking of running a'T' off the back of the manifold. One vacuum line to the power brake booster with an in line check valve the other to the PCV. My concern is will I have enough Vacuum to operate each? Could my idle/driveability qualities suffer? The engine is a 427 stroker small block using a Dart block and Cam Techniques HR-352 hyd roller cam- single profile, 110 deg. lobe seperation. The cam /engine build was designed for max performance without sacrificing good streetable drivability.
