04-17-2003, 10:37 PM
FL
Cobra Make, Engine: Hunter 427, 5.0 (302)
All you need is to mount the pump head at or below the bottom of the fuel cell. I had the same problem with my Holley pump untill I actually read the directions which state the pump should be mounted at or below the bottom of the tank.
Also do not make a tall loop our of the top of the tank with the fuel line. turn it back down as soon as you can so the fuel does not have to travel too far up hill before it goes back down to the pump.
If you hold the fuel line below the bottom of the tank fuel will actually flow on its own after it gets started. Just like a redneck fuel card(rubber hose in a fuel tank with a redneck sucking for the initial prime)
