Old 04-18-2003, 04:18 PM
RallySnake's Avatar
RallySnake RallySnake is offline
Since you'll be running the Targa event, your timing is not too important, so the Terratrip will probably work fine. If you have to do any TSD legs or just want to have more accurate timing, take a look at the Afla Elite. The navigator punches in the average speed that you want to maintain and the start time. As you run, the driver's display shows you "AHEAD" or "BEHIND" with the amount of timing error displayed. When you adjust your speed within a hundredth of a minute, the display switches to a graph showng exactly how much ahead or behind the perfect zero you are. These clocks can time you up to 300 miles per hour with amazing accuracy. My navigator and I both own one. We sometimes run with both to ensure that we will continue to run accurately even if a rock takes out one of the wheel sensors.
Man, if you were closer I would be proud to be on your support crew.
Paul
