  #22 (permalink)
Old 04-19-2003, 01:28 PM
rbray rbray is offline
Wow this is frustraing!!!!!
Here is what I have tried so far:
Bleed a front and rear wheel by having a friend slowly pumping the pedal. It didn't work at all the first time so we tried it again.
The results were better but not good enough.
We did the same procedure again, the results were better but got worse after a short drive.
Today I jacked up the front end of the car and did a gravity bleed on the fronts. Small bubbles came out of the drivers side for about 45 minutes. No bubbles came out of the passengers side.
I was careful not to let the resovior run dry.
I really thought I had the problem solved, but when I tested the car in the driveway the results were worse than ever.
Any help would be appreciated. It's a beautiful day and I would really like to drive my car.
Thanks for your help
Roger
