Thread: Carb Problem?
Old 04-19-2003, 08:57 PM
John A. Simpson's Avatar
John A. Simpson John A. Simpson is offline
Cobra Make, Engine: KMP 393 $27 S.O. bored and stroked to 482
Default Power Valve
David,
You may need a different power valve or your backfire may have damaged the existing power valve. The power valve opens at a specified vacuum level to admit more fuel, if your car doesn't make much vacuum (less than that required by your particular p valve) the power valve will open creating a rich condition, a blown valve will do the same thing but both should clear up at higher rpm when they would normally be open. Is your fuel pressure OK, 5-7 psi, if its too low you may have a miss, if its too high the pressure can override the needle/seat assembly and be too rich. I don't know of a simple test for power valve integrity without removal.
See you Friday
John
Sideways
