Thread: Carb Problem?
Old 04-21-2003, 03:49 PM
David Kirkham's Avatar
David Kirkham David Kirkham is offline
Original Shelby Owner
Smile
And the verdict...
I have to go back and work on Jamo's car now. Found the problem. Vaccum leak under carb between the gasket and the turkey pan. Pulled the turkey pan off and I am now waiting for the new gaskets to arrive. Until then I will drive without the turkey pan.
During the autopsy,
I took the carb off to check the power valves, (with my power lips I might add--yuck, that tasted bad. How come you can't ever wipe all the gas off?)
Anyway,
As I was tasting the gasoline--noticed the gaskets looked suspect. Took the turkey pan off to take as many variables as possible out and bolted the carb back down with a single gasket. Bingo...100 instant horses.
There is still an annoying stumble (not nearly so bad as before) in the 2000 rpm range. Probably caused by a lean condition as the butterfly is cracked for acceleration before the fuel can catch up. I wonder how to fix that problem.
I would sincerely like to thank all who responded to help out even though this has probably been re-hashed 10 times last month alone in other threads.
As a matter of fact, to all those who responded to this thread, please drop a line to rich@kirkhammotorsports.com and I will send you a Kirkham Motorsports shirt! Please specify size and we will get it out to you. Make sure you send the e-mail to Rich. I don't check my e-mail from this site as often as I should. Rich now helps me out to keep up.
Thanks for the site,
David
