Thread: Carb Problem?
  #49 (permalink)
Old 04-22-2003, 07:57 AM
blown blown is offline
Cobra Make, Engine: contemporary cobra
Default carb
david it sounds like you need to put the advance spacer in your dist that will give you 18-20 deg. in the dist. set your timming at 12 deg. initial and put the lighter spings in it make shur no one has messed with your pump squerters they shold be fully extended that should do it then you can slowly advance your timming until it slows your car good luck.
