Thread: Radar Jammers
Old 04-23-2003, 08:00 AM
Back in Black's Avatar
Back in Black Back in Black is offline
Cobra Make, Engine: West Coast. 514 / 6 speed Richmond overdrive
Default The only such product that works...
Is the lexan plate cover for plates, that has a stepped effect which makes all but straight on angle pictures distorted. This is effective because the cameras are at 20 degrees (or thereabouts) to traffic. I get this info from several friends who operate these cameras for a living.
The "spray" on coatings do not work, according to my sources. As to an active radar jammer, it would be quite expensive to produce since it would seem to need to sense the frequency used by the cop and then respond with the same or similar frequency in an altered state of some sort, something similar to the concept of "white noise" if you will. Then there's laser which complicates matters. IMHO these speed law enforcement tools are a direct assault on the human body since they are RADIATION of a sort. One has to wonder what a LASER can possibly do to the human eye, regardless of what trumped up "studies" may say. I consider them a low grade physical assault, but the "easy money" generated is apparently too powerful a temptation for them ever to be shut down now.
James Madison, father of the Constitution, said, "If Tyranny and Oppression come to this land, it will be in the guise of fighting a foreign enemy." He also said, "No nation could preserve its freedom in the midst of continual warfare..."
http://www.standdown.net/index.htm
