Old 04-24-2003, 01:07 PM
wicked fast's Avatar
wicked fast wicked fast is offline
The longest build.....
Cobra Make, Engine: Mid-States, 428 Police Interceptor, TKO 5 speed, Jaguar rearend, Trigos, and Guardsman Blue!!!
Question Relay info needed !!!
Trying to find relays for the horn and fan.
On the fan, I want to use a three position switch,
off/direct/temp sender
Will leave switch on temp sender side,
but can manually over ride if needed.
What part number/mfg relay should I use???
The other is for the horn.
Would prefer the old style instead of the little black Bosch relays.
Any help is greatly appreciated.
Bill Cook
If you were to die tonight, are you 100% sure
that you would go to Heaven ??
www.bluecarministries.com
