Old 04-24-2003, 01:34 PM
Cobra20646 Cobra20646 is offline
Shade Tree Mechanic
Cobra Make, Engine: - Unique - 302 - 4 spd. -
Bill
Fan relay should be rated at least 30 Amps. Horn relay usually rated the same. Both relays are normally S.P.S.T, or Single Pole Single Throw, meaning they operate like a normal on/off switch, turning voltage on or off.
For the fan, I would wire the fan relay to turn on by the thermostat or the switch, but wired so the switch cannot turn the relay off. I cannot think of a reason to over ride the thermostat and turn the fan "OFF". Too much risk of forgetting to turn it on until the engine overheats. If you're worried about not being able to turn off the fan in the event of thermostat failure, then make the fuse more visable, and use that to cut power to the fan.
Both of these relays are available at most auto stores like autozone, trac auto, pep boys...... nothing special needed here. Just pick out a 30 Amp SPST, 12 volt dc coil, in a style that suits your fancy
- Jim -
- Jim Harding -
- Capital Area Cobra Club -
- Just another day in Cobra Paradise -
