Old 04-26-2003, 06:18 PM
speed220mph's Avatar
speed220mph speed220mph is offline
Cobra Make, Engine: ERA 427SC w/427so, ERA GT #2002
Taking the weak-spring method another step, make sure you install a head gasket, then two lifters, pushrods and rockers for the intake and exhaust set to zero lash. The crank needs to be at TDC on the compression stroke when doing this. Don't forget you also need the cam and timing set installed, too. It would be helpful to have a degree wheel set to a known TDC for #1 rather than using divisions on the crank damper.
Rotate the crankshaft clockwise and bring it up toward TDC on the exhaust stroke. When the crank is about 15 degrees BTDC, push down on each valve until it contacts the piston. This will be piston-to-valve clearance at that position. Measure and record valve movement. Do this for each degree until the crank is 15 degrees ATDC, recording each clearance as you go. This will tell you exactly what piston-to-valve clearance is in the TDC neighborhood.
One thing this won't tell you is the position the valve is in relation to the piston, which is something you'll need to know if you're
installing larger valves with pistons flycut for smaller valves. That's another story.
Tom
"If you can make black marks on a straight from the time you turn out of a corner until the braking point of the next turn, then you have enough HORSEPOWER." Mark Donohue
