Old 04-27-2003, 08:27 AM
decooney's Avatar
decooney decooney is offline
Default Re: springs
Originally posted by jdeuel87
Duane,
Would using 9" springs rather than 10" accomplish the same thing as relocating the upper shock mount???
jdeuel87,
the short answer is yes.
The longer answer is this...
if you have a Unique with the coil-over upgrade in front, they are usually Carrera shocks. If you want to match the front/rear shocks and springs, and most do if they are the chrome coil-overs from Carrera, then you need to check with Carrera to see if they will make you custom 9" springs. The last time we did this, they only made the 10" or 12" springs. Also, the ride height in the rear depends on whether or not you have the wide or narrowed jag rear end. The wide is 55" and the narrow is 52.5" outside to outside. The narrow rear end pulls in the lower control arms a bit, which changes the mounting points below (angle) of the shocks/springs, which raises the car a bit more too (like 1").
Again, I would definitely check with Carrera but the most important thing is to give Carrera shocks your eyehole to eyehole measurements with the car sitting at desired height; also accounting for the mounting angle of the shock. They can help if you give them ALL of the information they ask you for. Aren't Cobras fun? Good Luck.
Duane
