Old 04-27-2003, 09:02 AM
jdeuel87 jdeuel87 is offline
Default 351 Alternator Location
I HAVE 351W CRATE MOTOR WITH EXPANSION THAT BOLTS INTO THE THERMOSTAT HOUSING[ PURCHASED FROM ENZO ] . I HAVE BEEN UNABLE TO USE THE MARCH ALTERNATOR BRACKET BECAUSE IT MOUNTS THE ALTERNATOR TOO HIGH[ AT THE LEVEL OF THE VALVE COVER] AND THE EXPANSION TANK IS IN THE WAY...WHAT TYPE/BRAND OD ALTERNATOR BRACKET CAN I USE TO PUT THE ALTRNATOR LOWER[ NEARER THE LEVEL OF THE WATER PUMP]...I'M ALSO USING MARCH PULLEYS, V-BELT, NO POWER STEERING...THANKS
