Tom
Tom,
This was a published test done on an engine dyno with one motor set up as the baseline and simply testing 4 different dampers. Temps, pressures, and all other values were the same throughout in order to determine which made the big HP.
Tom, Simple excelerating test performed on a superflow 901
Starting at 3500 RPM's and running straight up to 6500 RPM's
One had a significant advantage that will be posted Monday.
